跳转到主内容
修复你的物品
维修的权力
配件 & 工具
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
3290 个问题 查看全部
Problem With the Home Button
Hello all my first topic, thank you. I replaced my screen and digitizer some days ago, Was quite a traumatising experience, I decided I will not fix iPhones from 5 and below. after mounting everything and everything was almost ok I switched on the phone and everything great I am already jumping of happiness but than the Home button started pressing itself, I tried everything even alcohol drops but nothing. I than Unmounted the whole beast again suffering I managed to get into the home button and the screen I cleaned out everything with alcohol and closed all again, some minutes ago after a while wen I was cleaning after assembly, he made me this trick again and the Home button activated itself, I in desperance restarted and gave a good press and cleaned with my t-shirt the around. This phone is not mine and I dont want to give it back if the Home button Is acting crazy. Before he aswell freaked out and just stopped working. I am a bit in need here any good soul to help me out would be great
Bets regards Peps
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
yea it stopped working some seconds ago, I am sure it didn't helped to unmount the whole thing, and sometimes it changes mood and the voice control comes up
完成的
添加一条评论
基本电子产品工具包
小工具包。却有无限可能。
Shop Toolkits
基本
电子产品
工具包
Shop Toolkits
3个回答
已选择的解决方案
I would make sure that the home button comes flush with the screen. If it does then I would disassemble it and check the home flex that is underneath the physical button. If you can't fix it by cleaning I would recommend that you replace the home flex first and if that doesn't work then try the charge port maybe.
Hope this helps.
P.S. Not repairing the iPhone 5 or below? The 5s, 5c and 5 are almost identical and not to be a debby downer but the iPhone 6 isn't going to be any easier to repair. I would recommend lots of patience and practice. Never give up on repairing something no matter how tough it is. This is how you become a better tech!!! :)
这个答案有帮助吗?
得分 1
评论:
For the iPhone 5 and above I was talking for the digitizer and screen, I have a lot of crazy girls around here who somehow love to take a shower and jump with their iPhones around, result... The phone falls and the screen brakes. good moral compared to the 4 4s and bellow you now just need to take 5 screws lift a glass and its than fixed, on the others iPhones instead you need a full bunch of tools patience and cold blood. ;)
完成的
添加一条评论
最有帮助的答案
Have to agree with you on the repair of the iPhone 6 dosent look repair friendly..
Looks like the hole button will be soldered on them aswel
这个答案有帮助吗?
得分 2
评论:
Apparently people don't want insight on the future of repair (gets voted down) lol.
..Con I have noticed you answer just about everything which makes me curious on your experience with solder? Where I live I know for a fact that we are the only shop that is specialized in solder work which brings excitement for us when it comes to the 6. What does your solder experience look like?
完成的
Just got how add comment work xD, Sorry for late comment, So I live in Heidelberg In Germany :), I am basicly passionate with it I solder and fix everything I can find, and I never get demotivated, I as well can fix a bike 100% from A to Z including new paint, and not forgetting computers. my level of solder its something like I am able now to modchip every ps2 model on my own, if you see the level of difficulty, and size, I am talking about. Otherwise I can solder smd package probably felling confident enough around 0402 after that I wouldn't be scared of taking 0201 sizes but I maybe would screw the first boards, I bough all my soldering stations magnifying glasses tools on my own because I really do love this stuff :) want to do a formation in Germany but my papers are not valid here getting a hard time xD cheers
完成的
添加一条评论
Thanks all form those awnser, I purchased a new flex cable, now that you told me that it could be the dock I am terrified, the button is flushed and good. It's not clicking so we'll, I fell it compared to my 4s
Thank you very much all, have a move days
这个答案有帮助吗?
得分 0
评论:
Nice* writing from my phone xD
完成的
My new button came by today, I really tried to push it hard inside but there was nothing to do, there is like 0,5mm of gold connector out of the port, and the cable is a bit to long somehow... didn't knew if its normal or not I give a try, I had to buy some news screws set, I accidently dropped 1 screw and its now lost into the oblivion of my atelier xD
完成的
Yeap I installed the new button, even if it was a bit of the gold pad not going fully in, and it was a bit larger than the original, I decided to try, after I closed everything I turn on the phone, The screen come on its working the touch and screen are happily working, than I press the home button and blam worked just like magic with no trouble, I could notice the old one was so dirty on the sides that it fusioned with dirt and the pressure plate bellow was not returning to natural position properly, now its working good .
Thanks all
完成的
添加一条评论
添加你的答案
pepslight 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 110
