跳转到主内容
A collection of guides and support to help with washer repair.
3474 个问题 查看全部
Why won't my Zanussi Washer start at all?
Dear all.
Our Zanussi Jetssystem 1000 FJE 1006 washing machine won't start any program. The power is running, the door is definetly closed, water supply is OK. The chosen program can be adjusted and the time is being displayed. However the countdown won't count down, the water doesn't run, the machine makes no sound at all. Using the ANNULL.-Button I can jump forward within the chosen program, the displayed time is then decreased, but I won't start anything in the other "stages" of the program either.
What could cause this trouble? And how could I repair that?
I only found a manual in German – the troubleshooting there didn't help...
http://www.zanussi.co.uk/Support/Manuals...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Our member, Old Turkey, can read the manual. Maybe he'll find something. For now, unplug it for 5 minutes to allow it to reset. Plug it back in and see if you get any error codes.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the answer.
I tried what you suggested. No errors were displayed, same problem as before: The door is unlocked and I can choose any program I want but it won't start. :(
I hope, Old Turkey has some hints.
完成的
I guess Old Turkey doesn't look at washing machine questions.
完成的
添加一条评论
Hello I had the same problem with another make of washing machine, the problem came from a little device (I forgot the name in English) which checked that the door was closed. If you push around the handle of the door or on some places of the door maybe it will work.
Good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 7,821
