跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 个问题 查看全部
Could this be the cause for not powering up at all?
Here are pictures of the possible problem
I bought the whole computer from an auction as broken or for parts. Everything else works fine, except this
As you can see, someone did a poor solder job on the EFI chip (or is it?) and I wonder if it could be the cause for the computer not to power up at all. Even the fan doesn't go on. Nothing. It's dead as a door nail
So how would I proceed? I guess analysing the board with a multimeter could show what's wrong with it, but I don't have a clue how would I do that + I don't have much skill doing repairs at a component level.
Thanks for any help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Great that you added the pictures. What computer is it exactly and what are the last four digits of your computers serial number?
完成的
It's a 13" Mid 2013. The last 4 digits are F5V8
完成的
添加一条评论
1个答案
已选择的解决方案
Marhowl , it is absolutely possible. Yes, it looks like a repair including some bridging of the traces, really not a bad solder job:-). Since you do not know anything about the history of this IC you would not know if it even has the firmware programed before it was installed.
这个答案有帮助吗?
得分 2
4条评论:
It was owned by a 55 year old lady who bought it 2nd hand from someone and she didn't even know that it has been tampered with.
But from what she told me, I know this =)
* When she bought it, it worked for a month
* Then it wouldn't boot and would stay at the gray screen with the spinning thing
* Then it wouldn't power up at all. And that's how I bought it.
From what I have discovered, there was a really cheap flux that had a consistency of some cheap glue and it was all around the EFI unit. Could that cause damage as well?
Edit: I'm sorry for the formatting. I tried making it neat but it doesn't seem to work
完成的
Yup, formatting does not work on a comment:-) It is possible that the IC has either failed again or that there is a cold solder joint. You could try and resolder it and see if that will fix it.
完成的
So should I buy the programmed EFI chip and solder it there? Might be worth a try, right?
Only if I could solder or had the gear heheh. Got to find someone =)
完成的
That is the way I would go about it. By doing this you will at least know what is working and what is not. You are right of course, soldering on a logic board is not for the faint of hard. There are plenty of good people out there that do board level repairs
完成的
添加一条评论
添加你的答案
Marhowl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 852
