跳转到主内容
2001 Buick La Sabre Limited's RPM gauge drops to zero while driving?
My Buick's rpm gauge goes from working just fine to 0 in a matter of 20min. The car jolts a little bit when this happens and used to turn off completely while waiting at a red light/stop sign/idling. Can someone help me figure out whats going on?
Ive replaced the following:
Spark plugs/wires, fuel filter, serpentine belt, MAP sensor, Battery (brand new and 200$), gasket seals, oil change.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
A faulty crank sensor can cause rpm issues along with poor running conditions!
完成的
添加一条评论
2个答案
已选择的解决方案
When it "goes to 0," does the engine shut off, or does the car mysteriously recover and keep on working? Could it be a faulty ignition switch?
My Accord used to just randomly turn off while in the middle of driving, and it took me a couple of months to figure out my ignition switch was bad. I replaced the ignition switch and things worked perfectly since!
这个答案有帮助吗?
得分 3
添加一条评论
Can someone tell me why my 2000 Buick LeSabre speedometer not working RPM and Signal lights
这个答案有帮助吗?
得分 0
1条评论:
Did you get the problem fixed
完成的
添加一条评论
添加你的答案
tarah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 22
总计 2,740
