跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
3418 个问题 查看全部
Headphone Jack Static after Lightning Port replacement
I have successfully replaced the lighting connector assembly in my iPhone 5 and everything is working but there is terrible static in my headphone port. It sounds distorted and the controls on the headphone won't play or pause music. Is there a connection that I missed, or is this part defective. What can I check or tighten?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Ok So I decided to test a theory, I reinstalled the original Apple part theta had the lighting connector that doesn't work. The headphone jack works just fine. Still no ability to charge but that was the reason for the replacement. So It has to be another faulty part from iFixit. Calling customer support.
完成的
添加一条评论
1个回答
最有帮助的答案
did you transfer the tiny flex around the headphone jack? it is related to preventing interference in the jack
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
bderenski 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 641
