跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Why is my logic board overheating?
Hi
My 4s Logic board is overheating at the outlined position on the attached image
The phone works fine, but it overheats here even with just the battery connected to it.
I repaired the phone's LCD and silent-mode switch, but didn't test if it was overheating beforehand.
Do you know how i can fix this / what is wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
edd, overheating is usually caused by components having been shortcircuited. Check around your recent work and determine if any of the components around the connector have gotten damaged.
这个答案有帮助吗?
得分 2
1条评论:
The previous owner had attempted a screen repair and messed it up (the screen was all patchy with shadows all over it) and he also messed up the silent button which i fixed by un-tangling the flex.
So i'm thinking perhaps he caused this not me so I'm not entirely sure which connectors I should be looking at. I'll clean everything and try a new battery, but if that doesn't work I'm thinking something got damaged in the incident that prompted the need for a screen replacement, do you know which components I should test to try and workout what has gone wrong?
完成的
添加一条评论
I'm having this problem too. Please provide a solution.
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue, on a CDMA iPhone 4s, the battery was starting to go out and I replaced it today, this is now a backup phone but when it was my primary, I remember it being a very hot phone, even when doing something as simple as texting or calling. After I replaced the battery I was doing some testing to make sure I did everything right and it was really hot, so I took the back off again and touched the battery, nothing, touched mother board about 1 inch below the camera, and it almost burned my finger. What confuses me is nothing could have shorted before the battery replace, before that the phone had never been opened, it was more hot after the replace, but it was very hot before also. I don't know what to do. Thanks for your time reading this and hopefully I can get this fixed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
edd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,479
