跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Why is my iPhone not responding apart from showing apple logo
My iPhone 4 has stopped working for no apparent reason. I have tried turning it on, restarting it and pressing all the buttons and have had no response. When I plug it in to the wall or to my laptop the apple logo appears as if it is turning on. However, it just stays on the apple logo and does nothing. After a while it flashes and comes back onto the logo and will not get off it. As soon as I unplug it the screen goes black again. I have done nothing to the iPhone to cause this to happen and there is no visible damage apart from the obvious fact that it is not working in general.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
You have a battery problem replace and your good to go
这个答案有帮助吗?
得分 0
添加一条评论
I recommend restoring from iTunes using the DFU method there are many tutorials on youtube https://www.youtube.com/watch?v=uuulql2u...
这个答案有帮助吗?
得分 0
1条评论:
My iPhone doesn't appear in iTunes when I plug it into my laptop as it doesn't fully turn on because it is stuck with the apple logo. Therefore, I cant restore it etc or even back it up and take my photos off it before I restore it because my laptop doesn't register it.
完成的
添加一条评论
As @con suggested, this is mostly due to battery problem. For hardware problem better to call Apple support team to arrange a fix for that.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kitty 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 273
