跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2189 个问题 查看全部
Why does my phone now not charge at all after dock replacement?
My phone originally would only charge when turned off. So I replaced the dock, and headphone jack (for a separate issue). Now it will not charge at all. Any ideas? Did I forget to connect something, or not connect it back properly? I am bumfuzzled.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
The dock connecter plugs into the logic board and is cover by a plate which has 2 screws in it, (see image) aslong as you connected that connector it should charge unless you have a faulty dock connector.
try another replacement dock connector.
hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jema 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 48
