跳转到主内容
Nikon Coolpix 4600 digital camera which was released in February 2005. It has a 4-megapixel effective image resolution with a Nikkor 3x zoom lens.
Can I get a replacement battery compartment door?
The battery compartment door on my E4600 is cracked and barely usable when batteries are placed in the camera. I must use duct tape to keep the proper pressure on the door so it stays in contact with the batteries. Please tell me there is a way for this to be repaired with a new door!! I love this camera and would be extremely disappointed if this is not repairable.
Thanks,
Joe Dietz
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Did you ever get your Battery Door fixed??? if so please help me!!!
完成的
My camera is a Nikon 55 , and older filem camera . this camera takes the best
pictures
完成的
I also have a Nikon Coolpix L610 with the battery latch that won't stay closed when the batteries are in. It is due to a cheap and faulty design. I have a camera now that I cannot even use Frustrating!!!!!!
完成的
I have a Nikon L610 . I have to duct tape my door closed, I'm not spending $15 + to get a new door. Bad design as I've read numerous complaints abut the door not staying closed. My door is cracked, so too flimsy to hold the batteries in as the springs are super strong (that's a good design).
完成的
Same on my L620, and my older 7600. Dam Chinese parts on Japanese cameras!
完成的
添加一条评论
1个答案
已选择的解决方案
Here's what I found on eBay: eBay parts listing
Here's another link on getting the part directly from Nikon, they even sent them the needed instructions on how to replace the door! Fitya - Coolpix 4600
Here's the IFIXIT guide, sadly it only gets you part way there: Removing Nikon Coolpix 4600 Front and Rear case
Hope this helps! Good Luck
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Joe Dietz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,903
