跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Torn Front-Facing Camera Ribbon Cable causing screen artifacts?
I opened my phone earlier today to check for a loose power cable connection (the power button hadn't been working right since I replaced my battery) but opened it too quickly and tore the front-facing camera and sensor ribbon cable. Somehow, I didn't tear any of the other 2 connectors that connect the screen to the main assembly of the phone.
I figured it would be a quick fix, I just need to order another cable and then open up the phone, but when I tried turning on the phone to make sure nothing else had been damaged, it wouldn't boot. Instead I was met with these strange screen artifacts and nothing else.
I'm assuming the issue is still with that single cable (perhaps it being detached tripped some kind of pre-boot test in the phone and so it refused to boot), but I wanted to make sure I didn't need to order anything else. Could something else be wrong with the phone that's causing these artifacts, or is it just the detached front-facing camera and sensor?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Those boxes are usually indicative of a bad connection to the LCD. Where the bad connection is would be anyone's guess. The cable could have been strained where it attaches to the LCD, or it could have been bent, folded, stretched along it's length. It could also be the connector on the ribbon side, the connector on the logic board side or simply both of them where they meet. You may want to replace the LCD to get new cabling. If that doesn't fix it you are likely going to be dealing with logic board damage.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kurplenk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,164
