13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
620 个问题 查看全部
Airport Icon not showing up. No Airport card error
Macbook 13" A1278 Mid 2008
I have a late 2008 macbook unibody aluminum and it would not let me connect to wifi because arport was not an option. I bought a new airport card and installed it but even after that there still is no option for airport in network settings. Please help.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
5个回答
已选择的解决方案
Look under the Apple in the upper left hand corner to "about this Mac". Go down to the wi-fi and see if your machine sees the card.
这个答案有帮助吗?
按维修分数 2
评论:
This is what it says i don't think it sees it. (Picture is below)
添加一条评论
最有帮助的答案
First, click the + icon in network settings. Choose airport/wifi for the interface. Click create, then click apply. If that doesn't work, check the cable connections. If that doesn't help, replace the logic board.
这个答案有帮助吗?
按维修分数 2
评论:
i would have tried that but it doesn't even show up it only has ethernet, bluetooth dun and pan and ppoe and vpn and some other thing i dont know about.
and replacing logic board wont help as the airport card is completely separate from logic board. The weird thing is that the camara and bluetooth both work. Which share the same cable connecting the single wifi/bluetooth card
Hit the add button (+) and add the wi-fi to the list of options.
i already tried that no option for wifi show up
添加一条评论
Well it took a little while but i figured it out. It turns out the logic board connector had bent pins so i carefully bent them back into place and wifi works flawlessly now thanks for both of your answers.
这个答案有帮助吗?
按维修分数 1
评论:
of which connector you talking about? I have the same problem
thanks
添加一条评论
请参阅图像内容:
这个答案有帮助吗?
按维修分数 0
添加一条评论
Had the same problem Valiera .. with all the same symptoms and attempts ...
... a difference is a screw on the vent is shredded! I can't take the vent off and because of that can't remove the airport card! I hadn't checked the logic board pins, will try that next.
Thanks for your thread it lead to something new.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Valiera 将永远感激不已
浏览统计数据:
过去的24小时: 4
过去的7天: 25
过去的30天: 126
总计 5,484
