跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
314 个问题 查看全部
L5, power inductor broke off on my ds lite
So my niece dropped her ds lite and broke off one of the power inductors on her ds lite how do i fix this? Where can i order this part? How do i solder this piece on with out breaking the teeth? Is this the reason why when i power it on the green light comes on for about 2 seconds, the screen flickers then it turns off?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Hey mate. As its a SMD soldering job, its not going to be the easiest of jobs, but it is do able. This guide should hopefully help you on that part; http://www.instructables.com/id/Intro-in...
As for where you can get a new one, its a little tricky. After just a quick search I did find this place...but its in France;
http://www.reparation-ds.fr/nintendo-3ds...
You might be better off, if you cant do SMD soldering, to replace the mother board, plus its easier to locate. Heres a guide to replacing the mother board.
Nintendo DS Lite Motherboard Replacement
I hope this helped you.
这个答案有帮助吗?
得分 2
5条评论:
I saw the L2 L4 fuses but would that work for what im needing? If you look at the main picture of the mother board of the last link that was sent on the bottom left hand corner right above the headphone jack are 2 round circular pieces labeled "L5, L6" and right below the L2 fuse there is another one now ive notice they are not all circular some are square like the one i have.. What is that part called? Is it a power inductor? And how do i get one
完成的
I would suggest that you post a couple of images with your question. Use this guide 在已经存在的问题里加入图片 for that. It will enable us to see what you see.
完成的
OK it is a power inductor, BUT you would need to get one of the exact same value. Plus, from talking to a work colleague, if you somehow brake a SMD component off or damage one, you generally brake the track on the board. Also SMD soldering is pretty hard. You could give it a go if you wanted and its a 100 uH Ferrite-Core General Purpose Inductor I THINK, sorry i'm not to well versed on SMDs. You can get them pretty much anywhere
完成的
Zakk that is exactly what its called! Thank you so much for yalls help now i just have to find someone who isnt selling minimum of a 1000 :/
完成的
Haha its ok mate. It shouldn't be to hard to get them in smaller amounts, but I don't think you can buy just one.
完成的
添加一条评论
添加你的答案
Manny 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,048
