跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
914 个问题 查看全部
Home button unresponsive after changing front panel
After replacing the front panel, the home button is unresponsive. If I press the switch directly it works fine, but not with the button.
It doesn't seem to have something to do with the repair, but before it, it was working perfectly!
Any advice?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Hello,
You should check to make sure that there is a small black spacer on the home button flex. (It's very small) If its missing then you simply need a new home flex!
Hope this helps!
这个答案有帮助吗?
得分 0
1条评论:
Hi,
you mean the one pointed in this picture?
https://dl.dropboxusercontent.com/u/2184...
It is not missing... It is strange that if I press it with a pen it works, but not with the button...
Thanks!
完成的
添加一条评论
添加你的答案
luciacossio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 50
