跳转到主内容
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
Why won't it turn on after screen replacement?
I just made a screen replacement on an RAZR and it looks like it won't turn on. I made the repair following the guide. When I plug the charger, a white led turns on. I tried to hard reset it and nothing happens. What could it be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I've double checked it and it's connected. When I try to reset it. The logo comes up but instead of start up it just goes black and nothing work.
完成的
添加一条评论
1个答案
已选择的解决方案
Have you checked the connections of the three display cables?
这个答案有帮助吗?
得分 2
2条评论:
Today another RAZR came in with a similar problem and the battery flexible was ripped. So it might have something todo with it too.
完成的
Question: Did you check the battery? Of the RAZR from your original post?
完成的
添加一条评论
添加你的答案
Edgardo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 2,170
