Replaced Optical Drive with 1TB HD, mac continually not respondin.WTD?
Hi, hi have a unibody macbook pro late 2011 (model nomber A1286). i recently replaced the optical bay with a 1TB hard disk. I also upgraded to maveriks, and my computer keep not responding (when i use the finder, disk utility etc.) and also sometimes doesn't recognize the hard disk installed instead of the optical drive.
I used your guide (which is excellent BTW), but when i reached step 8, i stripped one of the screws and had to cut the plastic/metal in order to diconnect the bluetooth.
(i didn't cut any of the cables...
Can you help me figure out how to fix this problem?
Should i downgrade to Mac Mountain Lion OS X?
Thanks in advance,
Michael
9条评论
Can you give us the make & model of the HD you put in.
由 Dan 完成的
HI Dan, thanks for your help.
The HD Model is "Seagate Momentus Laptop HDD 1 TB SATA-300"
http://www.crucial.com/ProductDisplay?di...
Is this model compatible?
I used the link you provided, and it seems my EFI firmware is up to date.
Will try your suggestion (i have a USB case).
Thanks again
Michael
由 Mic 完成的
Just saw that my HD is 6Gb/s, can i do anything to make it work?
Also, i'd really appreciate it if you can tell me which HD model is fully compatible in the optical bay..
Thank you
由 Mic 完成的
Unless the drive has a means to slow the I/O speed to SATA II (3 Gb/s) there is no other possible solution here within the optical drive location internally.
由 Dan 完成的
Oh, i see. Does that it mean no other HD would be compatible?
由 Mic 完成的
显示更多的4条评论
