跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 个问题 查看全部
Why wont my charger work?
recently my charger stopped working. I have tried about everything. I have changed the usb cord, the cube i use to plug into the wall, and different outlets with the same result. There seems to be only one cord that works and it only works at a certain angle 50% of the time. I know its my phone but i dont know what i need to do to fix it. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
monique, from your description it appears that your micro USB port on your phone has failed. The repair will require some soldering. Disassemble your phone using this guide. Once you have the logicboard removed, unsolder the micro USB port from your logicboard and replace it with a new one. Here is a decent video, the port is widely available at many places. Just do a search for it. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
1条评论:
thank you. i dont feel comfortable dissembling my phone just because i dont want to mess it up anymore. But with this information hopefully it will be easier when i take it to a repair shop.
Thank you :)
完成的
添加一条评论
oldturkey03 has the right idea. The repair isn't an easy one, so I recommend looking for a repair shop that specializes in these repairs if you aren't up to the risk.
这个答案有帮助吗?
得分 1
2条评论:
thank you. Im thinking of going to a local radioshack that specializes in phone repairs. If you have any suggestions of better repair shops, please let me know.
完成的
Well there isn't really a big name in cellphone repair. You're best bet would be to look up shops and read their reviews. I hear Yelp isn't bad. Also don't be afraid to give some of them a call to get a feel of what they can do.
完成的
添加一条评论
添加你的答案
monique 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,653
