Nintendo handheld device released February 2011, identified by model number CTR-001.
324 个问题 查看全部
Nintendo 3DS Wont Charge But power's on with carger pluged in.
I bought a Nintendo 3DS on eBay, already fixed software issues.
But it wont charge so i bought a new battery. When I changed the battery I found a T righten on the back near the battery place.
I've put the Nintendo with the new battery back together but it still wont charge.
The console as almost no usage damage at all.
What can I do to fix this problem?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
1个答案
已选择的解决方案
Have you checked the charge port? I would say about 80% of these that I get have bad charge ports. If it's not broken then inspect it carefully to see if it needs re soldered (it probably does). If it looks good then I usually pry up the pins on the charge port where they meet the charger. I have a sharp straight pick for this that can get them.
I hope this helps!
这个答案有帮助吗?
按维修分数 2
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 606
