跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Phone powers down completely, then immediately restarts?
Hi-- this is my first time on here. I am 67 years old, not eligible for social security, and have no income. I bought a used iPhone 4s and found myself making multiple repairs, but that phone still has network connectivity problems. I am working up my courage to start micro-soldering (blue coil).
Anyway, this led me to try to start a business repairing and reselling iPhones. I'll be coming back to ask a lot of questions, but one at a time. On a particular phone, I replaced the digitizer and the back, and it worked! I sold it, but had not noticed that the replacement screen did not have a screen over the ear hole. The buyer wanted one, so she sent it back, I got a tiny screen and put it on, put the phone back together, and got a white screen (that question later). I replaced the digitizer again, and it worked fine, but by that time, the buyer wanted a refund, so I gave her one. I need to sell this phone again, but now it has spontaneously started--here we go-- finally-- to restart immediately after powering down, continuously, and this is causing the battery to run down in less than a day. Any advice?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
The charging dock port may have a short. Clean the iPhone charging port with a toothbrush and isopropyl alcohol very well. If still problem the next step would be replacement of the charging port assembly with flex cable, lower mic and home button flex connector all a single part.
这个答案有帮助吗?
得分 1
1条评论:
Thanks, I'll check it out.
完成的
添加一条评论
I'll second that...definitely a charge port problem that I've seen on numerous occasions. Basically, a short in the charge port makes the logic board think that something is plugged into said charge port, making the phone boot up again as soon as it is turned off. Cleaning won't likely solve the issue, but is always worth a try. Replacing will solve the issue though.
这个答案有帮助吗?
得分 1
添加一条评论
you probably checked this but maybe there is a stuck button.
这个答案有帮助吗?
得分 0
1条评论:
I installed a new home button, and it's a little mushy. I'll try changing it again.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 77
