跳转到主内容
The sixth generation Grand Prix, a front-engine, front-wheel drive vehicle manufactured by Pontiac, a division of GM. Sold in both coupe and sedan configurations.
41 个问题 查看全部
Won't accelerate when given gas.
This is an automatic 2002 Pontiac Grand Prix SE.
Just revs like you're in park and giving it gas. Uphill is a battle to get it over 10mph. Pressing down on gas pedal, it revs, won't accelerate. Checked to be sure the floor mat isn't shoved up under the gas pedal. What can be causing this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
kkhalid, " it revs, won't accelerate." sounds like a transmission problem. One of the most common causes of transmission slip is low automatic transmission fluid. Check the fluid. Other causes are the transmission band is worn out or broken.
这个答案有帮助吗?
得分 3
添加一条评论
I had an issue with my GTP where the transmission control cables were worn, causing extremely slow acceleration until it got to 2nd gear.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kkhalid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 2,135
