跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
问题已关闭
Can the digitizer be removed without breaking?
Hiya, I have done many ipad air digitizer replacements in the past but I have just done one for a friend and I believe I have got his digitizer flex cable caught between the digitizer and the frame (caught with the adhesive tape) as he says sometimes it works fine then other times it takes 2 or 3 presses to recognise touch input
Is there any way to remove the digitizer without cracking it to un-snag the flex cable this as I don't want to have to go out and buy him a new digitizer if I don't have to
Many thanks if anyone can help with some tips
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
It can be done but you will need to be very very careful it's also very easy to mark the glass on the inside and scrape away the white or black part of the glass
这个答案有帮助吗?
得分 0
添加一条评论
yes, We have done it. You can do it in all ipad types, 2, 3 , 4, mini's and ipad air. You have to heat up and then slowly make your way along the edges with heating consistently. Some people use some drops of super glue to attach the digitizer with the double sided tape. In these cases you will definitely break the digitizer.
Ipad air digitizers which we use come with original double sided glue.
http://www.aliexpress.com/item/5pc-sale-...
to remove these you will have no issues. Same goes for the ipad air's you need to open first time.
HEATING THE EDGES IS THE KEY. KEEP HEATING AND KEEP MOVING ALONG>
这个答案有帮助吗?
得分 0
添加一条评论
Like Ajaz said, it is possible. You need a temperature controlled heat gun, set to about 700 DF, and a good metal spudger to create an incision point on the corner of the device, and then about 8-10 guitar picks to slide gently around the perimeter of the digitizer, to de-adhere the glass from the frame. Time is on your side. Take your time, move slowly, and you should be ok.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,269
