跳转到主内容
In 2012, Sony Entertainment announced that the company would be releasing a new version of its 2006 Playstation 3 console. The new console is call the Playstation 3 Super Slim and is identified by the model number, CECH-4000. The PlayStation 3 Super Slim (CECH400x) is the third version of the PS3 video game console produced by Sony Computer Entertainment. It was released October 25, 2012.
210 个问题 查看全部
Why can't I turn on safe mode in my ps3 super slim?
Alright , so , I have tried to follow the rules in Playstation.com of how to get into safe mode but it doesn't work on super slim . I don't know if it doesn't even work in super slim , but the only reason i need it is that whenever I try restoring my corrupt data , it gets stuck at 47% . So when i tried using safe mode according to the rules given in Playstation.com , it beeps once then it turns on , and then another beep after approximately 5 seconds and then it's supposed to be two beeps rapidly but it beeps once and then the ps3 system turns off !
I need serious help , please answer.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
8条评论
I have the superslim ps3 console and i tried to update it to the newest update i tried to update several times and i get an error code now every time i turn on the system it tries to update all by itself and whenever i put it in safe mode it still is trying to update by itself. My ps3 is stuck trying to update and i can,t do anything about it. The last time it did this i had to get a new hardrive i do not want to get a second new hardrive. Please help me i do not want to get a hardrive every time my update gets stuck.
完成的
So please P L E A S E H E L P
完成的
I can,t aford to send it of to playstation everytime.
完成的
I can,t aford to send it of to playstation everytime. How do you format the hardrive to fat32?
完成的
My playstation 3 keep's shutting off every time I try to put it into safe mode and it's not displaying anything on my tv.pleeeeaaas help
完成的
显示更多的3条评论
添加一条评论
11个答案
已选择的解决方案
This is the way I perform the steps.
1. With the console "OFF", push power button and hold, it will power on, continuing holding the power button until it powers off.
2. Then release the power button.
3. Push and hold the power button again. It will beep and then double beep.
4. After that, release the power button and you should get the screen with the different options.
这个答案有帮助吗?
得分 4
3条评论:
Well this $@$* doesn't work . my controller is a wired controller meaning a USB cable controller. And I have hooked it in to the play station 3 and now my controller won't come on what should I do?
完成的
Get a new one, I don't know why it won't work
完成的
Same here, it tries to fix corrupt files, gets stuck at 47-48%....... try to get safe mode, when it says” hook usb controller up and push PS button, it will Not bring up the menu....it won’t recognize the controller, hence, it’s USB, and obviously won’t recognize wireless either....what a joke
完成的
添加一条评论
Hi,
Yes, it's work at super slim too. Switch off the console by holding the Power button (press and hold it contentiously until the PS3 powers off).
Now press and hold again the power button. Hold it until the console beeps 4 times (one beep, one beep, then two beeps), then release the Power button.
Now you are in the Recovery menu.
Regards.
这个答案有帮助吗?
得分 3
3条评论:
Thanks for letting me know that it works on in super slim too although I didn't quite understand the way you told me but u deserve it
完成的
Every time I try it it says connect the controller using a USB cable then press the PS button. And I am doing that and nothing is happening
完成的
It doesn't work for me, i get to the double beep and then it starts like it never happened.
完成的
添加一条评论
My ps3, like when I turn it on it says you didnt turn off the ps3 correctly and I press ok , it loads and stops at 77 and the start up shows and in the middle of it it freezes?
这个答案有帮助吗?
得分 0
2条评论:
Remove the HDD and format it at FAT32. Then install it and reinstall the firmware. You will lost your personal data!
完成的
This guy nailed the correct answer. Kudos mate.
Cheers from Riviera Maya, Mexico.
A cold beer will be available for you whenever come over
完成的
添加一条评论
Sorry but that answer is totally wrong
这个答案有帮助吗?
得分 0
2条评论:
What is the right way?
完成的
Which answer? Telling someone they are totally wrong without a correct answer helps no one.
完成的
添加一条评论
I did this but got hung up on the connect the controller screen. I pressed the PS button but nothing.
这个答案有帮助吗?
得分 0
1条评论:
Add a usb to the controller and connect it to console and then click on the 3rd option
完成的
添加一条评论
my playstation will turn on but not boot at all, nor will it get into safe/recovery mode. blank black screen and no sound. only way I herd was to but a new hdd and download the newest ps3 system update off the website onto a thumbdrive from a computer. then, slip new hdd into ps3 and safe mode should work and install update from thumbdrive from safe/recover mode and should be good from there. and you may be able to save some game data off the old hdd by getting a external hdd cradle and hooking it up to the ps3 usb and get into safe mode/recovery mode and go from there. or take your hdd and stick it into another ps3 and try safe mode from there.
这个答案有帮助吗?
得分 0
添加一条评论
Nothin is helping me I've tried all the solutions on here and still nothing. I'm to the point where i'm going to smash this dam thing Any other suggestions i'm open to all help.
这个答案有帮助吗?
得分 0
1条评论:
I turn on the ps3 until first beeps and held till 10 seconds then come the 2nd beeps then my ps3 shutdown. Then i try the same thing again hold the button with first beep then hold for 5 - 10 seconds but i didnt get the 2 rapid beeps, just like the first time, beeps again and shutdown. Pls help :(
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
I did it, opened the menu, selected rebuild database, it froze at 0% the first time. I unplugged it, tried getting back into the menu, it started automatically rebuilding the database, got to 9% then the screen went blank. I waited 20 minutes, unplugged it, now it won't go back into the menu screen. I'm lost....
这个答案有帮助吗?
得分 0
添加一条评论
Hi,
Bought one used for Christmas for my kids and went to run update and wipe it clean and I got stuck in the update loop like everyone else on this thread. I just found out this was a jailbreak PS3…is that why I can't get safe mode to work?
这个答案有帮助吗?
得分 0
1条评论:
why ps3 its stucked on system recovery mode, and whenever i tried to turned it to safe/recovery mode, i beeps
1 beep then 3 consecutive beeps and the power turns off again. Please help me to solve this problem.
完成的
添加一条评论
you need oringinal ps3 controller charger
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Death1024 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 143
总计 61,684
