跳转到主内容
The LG Optimus G was announced on September 19, 2012. It is a smartphone designed and manufactured by LG Electronics. In the US it is available through AT&T and Sprint. AT&T carries the 8-megapixel camera E970, Sprint offers it with a 13-megapixel-equipped LS970 model.
28 个问题 查看全部
Why my lg optimus g e970 doesn't turn on?
after unplugging my phone to the charger, it showed a yellow screen that said:
HW reset was detected!
DemiGod Crash Handler: HW reset was detected!
Press key to choose Dload Mode / Reboot / Fasatboot.
1) Vol up: Dload mode.
2) Vol Down: Reboot.
3) Power: Fastboot
If you choose Dload Mode,
Please do the Following action.
1) Dload Mode. Please connect USB
2) Get the ram dump image using QCT's Memory Dubug App
3) Send email to contact point or M-TDR_Leader@lge.com
after that, press the power button for 15 seconds, and the phone was shut down and will not be returned to power on..
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 3
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
1个答案
This may not answer your question completely, but that screen can be reached when an app crashes your phone. The part about it not being able to turn on is a little more unsettling. If you're willing to go out on a limb, you could open up the back of the case and remove-reconnect the battery.
If it doesn't boot after this, you may have to do some serious hardware debugging. Generally if your phone can't even get into recovery mode, it's a bad sign.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Carlos 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 5
总计 2,590
