跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 个问题 查看全部
How to remove trackpad from MacBook Pro 17" Unibody Mid 2009?
Hello
The trackpad in my mid-2009 17" Macbook Pro has developed an unresponsive patch so it seems a replacement is in order.
I have watched a number of videos in which people remove the trackpad from a Macbook Pro but none of the machines involved appear to match my internal configuration.
Specifically, the connector from the trackpad seems to run under the processor. It is as though I need to remove the processor from the logic board in order to disconnect the trackpad.
Can anyone advise whether this is correct or how else I can disconnect the trackpad?
Sandy
The spec of my machine: http://support.apple.com/kb/SP546
Relevant images:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
You are correct. A track pad replace (or even an top case replace) on this model is a major project. As a workaround consider using either a Blue-tooth mouse or track-pad.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
7条评论:
Thanks for the reply. Can you provide any more detail about what would be involved?
完成的
Nope - never done one but it should be very similar to this: .
完成的
Thanks for the link. A major project indeed. Do you have any tips for breathing life back into the trackpad without replacing it entirely? I've tried a number of software approaches (PRAM, SMC reset) to no avail but maybe there are other techniques?
完成的
There are no software fixes for hardware problems.
完成的
I thought I'd follow up to say that I sourced a replacement trackpad on Ebay and was able to fit it without removing the logic board by running the new cable up the side of the battery. So far, so good.
完成的
显示更多的2条评论
添加一条评论
interesting... do you think you could have just disconnected the trackpad cable and used that cable for the new trackpad?
这个答案有帮助吗?
得分 0
添加一条评论
I had that after a replacement of the Graphic Card in an official Apple Store every contact to the pad getting interpreted as klick which never get released and in my case it helps to release the Big screw in the middle of your second pic a little bit. If that don`t help here is a tutorial how you can replace it > in short the difference to the 15"-Version is that you have to release all 6 screws and let the "processor from the logic board" untouched! >
https://www.youtube.com/watch?v=SVFC4Ppy...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sandy Cooke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,913
