跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying.
950 个问题 查看全部
Ipad needs to cool down before use it!
I Bougth an used ipad and after several minutes I get this message " Ipad needs to cool down before use it". The ipad is not hot. I tuned off the ipad and turn it on again, then after several minutes again. I get this message. The process is repeated every time. Please advice.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
5个回答
已选择的解决方案
Have you tried restarting it and then try wiping it down and carefully re-install your apps (Apple App Store apps only). Is it now stable?
If either fixed it, something you have downloaded or installed is using the CPU hard so your iPad is overheating.
这个答案有帮助吗?
按维修分数 1
添加一条评论
最有帮助的答案
This is board damage. I have seen it before. If you have a hard time finding someone to repair it, you could look into my complex diagnosis repair on my website (click through my profile to find)
Jessa
这个答案有帮助吗?
按维修分数 3
添加一条评论
One advice:
Don't buy second-handed stuff that you can't inspect throughout unless you absolutely trust the seller.
iPads are difficult to inspect/repair but easier to fake good condition. This iPad probably have been improperly repaired from water damage as water damage is the most common cause of false overheating alarms.
这个答案有帮助吗?
按维修分数 2
添加一条评论
After opening up the ipad, i found that the PMIC has been repaired by Apple before. There was also alot of solder ball around the area. C8155 and C8156 had some solder lead almost shorting at each other. So I took a tin foil to cover PMIC before removing both caps. I was using small noozle and heat around 315 deg to remove the cap. After reworking, testing the board now.
这个答案有帮助吗?
按维修分数 0
评论:
Repaired by somebody---probably not Apple. Correctly done BGA should not leave solder balls---that is a sign of too high heat.
添加一条评论
This is bullshit. Apple knows why this is happening. It's programmed obsoletion and I won't be party to it. I'm switching to Samsung.
这个答案有帮助吗?
按维修分数 -3
评论:
Really, so anyone who has a working unit (most of us) just don't know it's obsolete. We have over 200 of the iPad2 units in the field and they are all cool to the touch an we are using the latest version of the apps we use.
It is simple component damage. Not unlike a brake sensor on a car failing after a couple of years. But maybe you're right. Toyota is bullshit, I'm switching to Honda.
So if anything breaks, it's Apple's fault?
No, Honda is bullshit I'm getting a Kia! ;-}
I think it's all bullshit. Buy a bicycle;-)
显示更多的1条评论
添加一条评论
添加你的答案
Ramon 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 14
过去的30天: 46
总计 5,171
