跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
问题已关闭
Phone doesn't react – How can I find out what's wrong?
Hey everyone,
I was using an iPhone 3GS which I bought in January 2010. My power button hadn't been working for a while now but I could get around with Apple's native Assistive Touch. I realized over the last days that my battery had become very short-lived compare to before, and one day after I had just fully charged it, taking it out of my pockets it didn't react at all anymore. Plugging it in again there wasn't any reaction either.
How can I find out what happened to the phone? My wild guess is that the battery just stopped working, but any other suggestions are welcome. What should I do as a first step?
Many thanks for your help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Duci, before anything else, replace the battery. This will give you a clean known to be good starting point in case you need further troubleshooting. Hope this helps, good luck
这个答案有帮助吗?
得分 0
1条评论:
Thank you, Old Turkey and Mitch Rush, for your answers. I have a 3G battery readily available, is it adviseable to build it in my 3GS just for checking whether the battery is actually the problem? That would speed up the process enormously…
完成的
添加一条评论
Duci, I agree with Old Turkey,, if you are still having problems after a new battery than I would replace the dock connector.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 361
