iPhone not boot up, can not restored. Error 2001
iPhone not powered up, can not restored. Error 2001.
Booting up only from wall charger, charging. After country
selection-showing Connect to iTunes.
I try to restored from iTunes but every time same fault-2001. Some of the with the same fault has a battery problem. I replaced battery today, but still the same problem.
Leave on charger over hour. Still the same.
When phone connected to the charger after 5 min screen become grey and
phone stuck until disconnect
由 Vitali 完成的
Previously has a minor water damage. I did pull logic board out and cleaned with alcohol. No any signs of corrosion or any other damages on the board.
由 Vitali 完成的
Found short circuit at the battery connector at main board. Power I/O
is heating up when charger connected.
由 Vitali 完成的
