跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2191 个问题 查看全部
问题已关闭
iPhone 4s earpiece not working tried replacing
Hi, I have experienced this a few times, I had a phone come in and the earpiece does not work, I changed the proximity sensor as the power button didnt work either and also changed the earpiece but that still does not work, what else apart from the earpiece and the contact strips on the board can prevent the earpiece from working? Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Sounds like you have a bad audio chip, almost impossible to fix, sorry, if you had a 4 instead of a 4S I would have an easy fix, the only other option would be that the headphone jack is dirty or has failed and is stuck on headphone mode so all audio is being sent there when on a call, try this make a call take the phone away from your ear watch the screen, turn volume up and down while on call and see if the volume on the screen says (heaphones) while your adjusting volume if it does than you need to clean or replace the headphone jack, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
Well the earpiece is only stuck to the proximty power cable so either u have damaged the cable or it's not plugged in correctly..
And make sure u have the earpeice installed the correct way with the gold prongs pointing toward the top of the phone
这个答案有帮助吗?
得分 0
1条评论:
Hi, thanks for your reply, I know the earpiece is only stuck to the prox I was just explaining that got changed also. Yes the gold prongs are facing towards the top of the phone, I have tried 4 new earpiece and still not working, I am wondering if there is anything else that can stop the earpiece from functioning?
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,403
