跳转到主内容
The HTC Desire is the first smartphone of the Desire series developed by HTC.
49 个问题 查看全部
My HTC shutdowns all the time
Hello
I don't know what is going wrong, my HTC shutdowns. I can't turn it on, when I push button.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
1个答案
已选择的解决方案
Hi,
- Check battery voltage, remove the memory and the SIM cards.
- If the battery is OK, with the battery in pres and hold the power on button ~30sec.
- Try to connect the phone to PC and check if the Windows recognize device. If no - then you have a hardware problem and you must find mobile phone technician.
- Try to enter Recovery mode (press and hold Volume Down then press and release the Power button). If you see the Recovery menu, select "Clear Storage" (this is full factory reset, you will lose all yours personal information).
- If this not help you then you need mobile-phone service.
Regards.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
Bartosz 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 68
