跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Can A Virus on Windows7 Via Parallels5 affect my Mac?
I run Windows7 Ultimate using Parallels5 on my MacBook. While running a virus scan with "Parallels Internet Security" application, it has discovered a Trojan Package: 'packed.win32.tdss.z". Can this Trojan affect my Mac outside of the virtual machine? I tried ridding of the virus with the software that detected it, but was unsuccessful. Does anyone know what this virus does and how to rid of it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Your Mac is fine. The only affected part is the one you stuck in windows. + for the question.
完成的
+ Ralph
完成的
添加一条评论
2个答案
已选择的解决方案
Not at all, a not only is it impossible for anything to exit that VM, but windows code simply can't execute on a mac, windows viruses work on windows, mac viruses work on macs. Imagine trying to open a windows application on a mac, just can't work.
这个答案有帮助吗?
得分 1
5条评论:
I think majesty got his pack of cigarettes at the gun store. Walking uninvited into a room with the two of us is just not a good idea. Be advised. Back slowly out the door.
完成的
you gave a comment not an answer. It's "Your Bad".
完成的
I am REALLY confused right now, someone had an answer, I answered it, now you try to tell me to leave, claim my answer is not an answer, and downvote it.
Despicable, I really thought better of you mayer.
完成的
I'd agree that Windows code can't be executed on a Mac, but your Windows partition may end up with a lot of crap on it as a result. More importantly, the Mac can still send out the virus (if it's a worm) to other fellow Windows users and infect them.
完成的
yeah but it first has to get out of that VM, which won't happen
完成的
添加一条评论
最有帮助的答案
To remove Packed.Win32.TDSS.z, you must first stop any Packed.Win32.TDSS.z processes that are running in your computer's memory. To stop all Packed.Win32.TDSS.z processes, press CTRL+ALT+DELETE to open the Windows Task Manager. Click on the "Processes" tab, search for Packed.Win32.TDSS.z, then right-click it and select "End Process" key.
To delete Packed.Win32.TDSS.z registry keys, open the Windows Registry Editor by clicking on the Windows "Start" button and selecting "Run." Type "regedit" into the box and click "OK." Once the Registry Editor is open, search for the registry key "HKEY_LOCAL_MACHINE\Software\Packed.Win32.TDSS.z." Right-click this registry key and select "Delete."
Finally, to completely get rid of Packed.Win32.TDSS.z, you must manually remove other Packed.Win32.TDSS.z files. These Packed.Win32.TDSS.z files can be in the form of EXE, DLL, LSP, TOOLBAR, BROWSER HIJACK, and/or BROWSER PLUGIN. For example, Packed.Win32.TDSS.z might create a file like
%PROGRAM_FILES%\Packed.Win32.TDSS.z\Packed.Win32.TDSS.z.exe. Locate and remove these files.
这个答案有帮助吗?
得分 2
9条评论:
Ur the best Mayer, I'll give it a shot and I'll get back to you. In the final part of the process, are these files also under the registry?
完成的
Mayer, there is no such file under the processes.
完成的
We've reached my PeeCee limits boys. Wait for Chris Green.
完成的
This is why I went Mac to begin with. I only use Windows when absolutely necessary, normally stuff involving school.
完成的
And here I am about to finish my latest high end build. Tower with multicore AMD and lots of gaming memory. If not for the games I might go Linux but will probably use Win7. Ralph
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Majesty 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,719
