跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
问题已关闭
After screen replacement no visual only backlight
upon pulling apart an iphone 5s the screen will not show anything. The back light works but the screen does not. I have tried the old screen and it does the same thing. i have even tried 5 other screens with the same results.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
If all the screen are doing it then I would look at the lcd connector on the motherboard and check for bent or missing pins
这个答案有帮助吗?
得分 0
1条评论:
already checked the pins they are all good
完成的
添加一条评论
Only other thing is a fault with a componant on motherboard you will need a shop that is good at board repairs..
I recommend Jessabethany on this site she has great knowledge with board level repair
这个答案有帮助吗?
得分 0
添加一条评论
I had the same thing and after a restart is works fine. but now even with restart it won't work still backlight only and before this happend my screen went white.
what do i do because the %#*@ repair &&^&@@ my iphone
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 394
