跳转到主内容
修复你的物品
维修的权力
商店
Samsung's second-generation smartwatch, released in April 2014 and powered by a Tizen-based OS. Model Number:SM-R380.
61 个问题 查看全部
My Gear is unable to connect to other devices like my phone
I turned both my Gear and my smartphone's bluetooth on, but they're still unable to connect! I believe they're within range also.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
First, make sure there aren't any obstructions between your Gear and your Bluetooth device. Walls or other obstructions between the devices could weaken the connection and result in a bad connection.
Second, update any software for the device. If the latest version of the Gear Manager application is not installed and up to date, it may result in being unable to connect the devices.
If neither of these work, try resetting your Gear. When it powers back on try connecting to the Bluetooth again.
If it is still not working, contact the Samsung Service Center.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonathan Molina 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 593
