跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
216 个问题 查看全部
My iPod touch wont turn on at all and its fully charged
My iPod touch wont turn on at all.I tried connecting to computer and it syncs and it makes that noise when you connect your iPod to computer but the iPod doesnt turn on at all.I thought it wasnt charged but my computer tells me it is fully charged so I dont know why it doesnt turn on. I did connect the iPod touch to a cassete input to hear my music in my big stereo. It played like three songs and then it turned off and from there on it didnt turn on even when i charged it and connected to the computer.What should i do is there a solution?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
I had this problem im pretty sure, with me i spent 2 days on finding out what is it by following error codes but i finally got to down to error code 1 which is hardware malfunction i belive and with that im pretty sure there is nothing you can do about it except get it fixed by a professinal.
完成的
添加一条评论
7个答案
已选择的解决方案
It sounds like you have a bad battery. Use this guide to replace the battery.
这个答案有帮助吗?
得分 4
添加一条评论
最有帮助的答案
I had the exact same problems you described:
try this it worked for me,,,
when connected to itunes, hold down the home and sleep button together for 10 seconds, this should restart the iPod and the apple logo will appear,thanks
这个答案有帮助吗?
得分 18
15条评论:
THANK YOU THANK YOU DAVID.I thought I would lose it! Then it was revived by this David's-Ipod "CPR".
完成的
thanks david that worked for me hold home and sleep down for 10 seconds
完成的
If the iPod connects to iTunes and can sync without the screen ever turning on then your problem is most likely your screen. There's a guide here on how to replace it. Gook luck
完成的
OMG DAVID THANXS SO MUCH!!!!!! u saved my ipod it worked!!!!!*SQUEEL*
完成的
do you reset your ipod when you do this
完成的
显示更多的10条评论
添加一条评论
Just hold down the sleep button at the top and the home button at the bottom. Wait ten seconds and then it should restart.
这个答案有帮助吗?
得分 3
3条评论:
Works perfectly. It helped mine because it just did it.
完成的
I held it for 30 seconds and it turned on! Thanks so much!!!!!!!!!!!!!!
完成的
Thank you it worked yay!
完成的
添加一条评论
(Ipod 5 generation 32gb). My ipod 5 won't turn on (Black screen) But it keeps making a beep sound like its on but nothing nothings on the screen??? The screen is black but it makes no noise?? Do I take it to a professional to see if it still works???
这个答案有帮助吗?
得分 2
添加一条评论
mine didnt work
这个答案有帮助吗?
得分 0
1条评论:
any other options
完成的
添加一条评论
https://www.ifixit.com/User/237403/Amand... what u should do is hold the home screen button and the lock screen button and see if it turns on ur charger might be broken this happened to me. Everyday I tried to turn it on and I couldn't get it on I left it on the charger for four days then at my basket ball turnament I told my friend and she said that if I push the home button and the locks teen button that it might work and what do u know it did plz contact me back if it worked for u
这个答案有帮助吗?
得分 0
1条评论:
what if your home button is broken
完成的
添加一条评论
my ipod screen jus went blank/black...its did this many times and i just go straight to holding the sleep/wake button and the home button but funny story my home button is broke and i've took this thing to a shop to fix the screen but they did a lousy job(rushed) so maybe thats the problem? i can hear the charging sound when i charge it and it has charged overnight so can someone please help me out here i have no other options
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amanda Tarin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 22,563
