跳转到主内容
The LG Optimus G was announced on September 19, 2012. It is a smartphone designed and manufactured by LG Electronics. In the US it is available through AT&T and Sprint. AT&T carries the 8-megapixel camera E970, Sprint offers it with a 13-megapixel-equipped LS970 model.
23 个问题 查看全部
Do I have to replace it or cani fix it?
My friend dropped my phone outside face first and the screen cracked the whole screen. It turns on and off and the screen is normal looking, but the touch doesn't work anymore. I can't unlock it or anything. Can I get it fixed? Or do i have to replace it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Matthew Enriquez, you will not have to replace your phone, but you will have to replace the display assembly. Here is a decent video. The part is available at multiple places and will run anywhere from $60 and up. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
5条评论:
Thanks buddy :)
完成的
anytime Sir, anytime. Welcome to ifixit.
完成的
Hey i took my phone to be repaired at the sprint store and they said to replace it? Should i take it to a repair shop?
完成的
Matthew Enriquez, yes I am certain Sprint would want you to replace it. Now its a matter of economics. It's a matter of your skills and your money. It will definitely cost you the above quoted amount and you will have to work on it. See if you are comfortable with that. Weigh all this against whatever Sprint will charge you for an "upgrade":-)
完成的
Thanks a lot, i really appreciate your help
完成的
添加一条评论
添加你的答案
Matthew Enriquez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 399
