How similar would the repair guides be for the other Xoom versions?
I am concerned that I have a different version. I appreciate the organization in the repair guides for this one. It would be convenient if I could simply use these guides.
The only difference between the Motorola Xoom Wifi and the Motorola Xoom 3G/4G is that the 3G/4G version has the ability to connect to the cellular data network. Where the connector and antennae would be in the 3G/4G version, there is just blank space in the Wifi version. If you are careful, you should be able to repair your Xoom with these guides.
这个答案有帮助吗?
Thank you Mallika. And such a quick response.
Jelly Bean 3.4 4.1 or 2 whenever you can I get it to upgrade to a newer version And I have another tablet to an older one because the Verizon model and It can't Can't do nothing on it I tried to reset it and make it work again and it Coming back saying that one wire is broken or something then it's not taking a charge but when you plug the charger into it it charges up. Do I need to send to somebody or can I take it apart myself and fix it Thank you
这个答案有帮助吗?
Dad asking a question I didn't know it said something about an answer I don't know s*** about whatever the question was so I'm looking to have somebody answer my question. Answer to question anything
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 409
