跳转到主内容
修复你的物品
维修的权力
商店
Repair and troubleshooting information for the Suzuki FA50 Moped.
78 个问题 查看全部
Why does it get 4 miles to the gallon with no leak?
This bike runs great but I am getting 4 miles to the gallon. I have searched and cant find a leak. What on earth could use that much gas? I cant just be the carb adjustment, right? I am out of guesses.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
评论:
Well, it blows my mind, but after slightly adjusting the air and fuel screws...perfect fuel consumption. I rode all the way to work yester and no noticeable fuel use. Who says there is no ghost in the machine? I love this bike and everywhere i go people like it. Cracks me up when guys on big machines nod at me. Maybe they had one when they were kids? How come i cant post a pic? Its a yellow 82, with all the lights and plastic. Be nice to share. Thanks "oldturkey03"!
完成的
L E Will , great to hear you got it fixed. Yes you can share your pics. Just place them with your original question. Here is a "quick and dirty" guide on how to add images. Love to see what it looks like:-)
完成的
tell you the truth i am so sick of tire maintenance i am ready to throw the bike out. i have gone thru 4 tubes.
完成的
And i need that bike for transportation.
完成的
I hear you. not easy to keep some of that old stuff roadworthy and getting parts.
完成的
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
1个回答
最有帮助的答案
L E Will, it is possible that this is caused by really bad carb settings. Your air/fuel mix is potentially way off. Download the service manual from here. Pull out the spark plug and take a look at the face. see if it is light bown and dry, or black sooty. Check your carb settings. If your carburetor is okay and all the settings are correct, you do want to do a compression test to see if it is possible that your rings are leaking. Also, do check the reed valve and make sure that it functions properly.
这个答案有帮助吗?
得分 2
评论:
Okay, thank you so much. I hope its the carb! I will play with it tomorrow, before the sun gets too high. The guy i bought it from was messing around with the carb and he had the choke set really weird too. Wish me luck!
完成的
Good luck and let us know how it turns out.
完成的
添加一条评论
添加你的答案
L E Will 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 545
