Ipad Casing is bent - What is recommended fix?
Ipad was dropped on one corner and is slightly bent. I don't see the casing as a product so I'm assuming that slightly hammering it back into shape is the solution?
if you don't do a lot of repair, it is not worth investing in a g-tool. A g-tool will bend an ipad back into perfect shape. See if you can find a local shop that uses these---they are very new, so you might want to ask eTech parts who might have one in your area.
这个答案有帮助吗?
Best not to do anything here.
In the process of banging it I'm sure you'll end up cracking the glass.
Just put some tape around the edge to cover any gaps. Not pretty, but will get the job done. Otherwise its' time for a new one.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 299
