跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
Bad cell signal, not sure what part to replace.
I recently repaired my iPhone and now I have really sucky signal. I tried cleaning the contact clip and the fingers of the cell antenna but I still have very bad signal. I am not sure if my iPhone needs a new contact clip, cellular antenna, or a logic board. (I can't solder an iPhone induction coil even if my life depended on it.)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
What did you do for the repair?
这个答案有帮助吗?
得分 0
1条评论:
I had to replace the backing and the home button.
完成的
添加一条评论
Make sure the fingers of the antenna are pushed down and making contact with the frame!
If that fails I would try a new one to rule out a fault part..
Failing that you have damage the logicboard in some way
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 87
