跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 个问题 查看全部
问题已关闭
Will Samsung SSD 840 EVO use it's full potential?
Hi,
I've decided to upgrade my old iMac.
It's an 20" mid 2007, Processor 2.4 GHz Intel Core 2 Duo, EMC 2133.
I've invested in a Samsung SSD 840 EVO, Model: MZ-7TE500.
I've looked around in the "Answers" for Device; "iMac Intel 20" EMC 2133 and 2210". And I have one concern... Will it use it's full potential on my old mac?
Kind regards,
Eirik
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You may find going with a hybrid drive (SSHD) would be a better setup for you.
A hybrid drive is a standard HD with a SSD mounted with it to act as a very deep cache. The benefit of using a hybrid is you hold onto the large storage of a HD but get the quickness of the SSD. These drives are also cheaper than a straight SSD and you don't need to swap out the optical drive if you want both your HD and SSD (less work) and you'll get the best I/O for your storage.
这个答案有帮助吗?
得分 2
添加一条评论
Your iMac has a SATA II (3Gb/s) bus for the hard drive slot. The 840EVO supports up to SATA III (6Gb/s).
In short, you won't be able to truly use the SSD to its fullest potential. That being said, installing the SSD in the iMac will still make a very noticeable increase in speed and responsiveness.
这个答案有帮助吗?
得分 1
2条评论:
Thank you for the reply.
Is there ways to make my old mac SATA III compatible?
完成的
Sorry no you can't upgrade the SATA port logic on your logic board.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 451
