跳转到主内容
The Dell Inspiron 1500 is a laptop computer designed for home-entertainment with a narrow border for a wider viewing area.
16 个问题 查看全部
What is the procedure for replacing my Dell laptop's keyboard?
My daughter's Dell laptop keyboard has failed.
Can I repair or replace it, or must the keyboard be repaired or replaced by a qualified technician? If I can replace it following a procedure, where might I find the procedure?
I don't see Dell keyboard replacement procedures in iFixit.com.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Check these two links:
http://support.dell.com/support/edocs/sy...
http://support.dell.com/support/edocs/sy... (This is the manual, the guide with pictures starts on page 109).
This info should be enough for you to be able to do it yourself. Also, it would be great if you could create a repair guide for iFixit for doing this. It'd be a great help to people later on who want to be able to do this
这个答案有帮助吗?
得分 2
1条评论:
Research + Ralph
完成的
添加一条评论
check out this site: http://support.dell.com/support/edocs/sy...
这个答案有帮助吗?
得分 0
1条评论:
rab has already listed that site.
完成的
添加一条评论
you can visit '''Dell Technical Support''' to resolve your issue. you will get a manual guide here from which you can easily learn about replacing dell laptop’s keyboard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
LeRoy Younglove 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 5,072
