跳转到主内容
Repair guides and troubleshooting for the HP Compaq DC7500, a business class desktop computer introduced in 2007.
25 个问题 查看全部
hangs at setup is starting windows
hi! how are you? every operating system installed good on my machine except windows xp. i installed windows 7 and also vista both installed good but when i try to install windows xp, a every time my pc stuck at "Setup is starting windows."i changed my dvd rom , also try to install window with my bootable usb , the problem is still same. windows xp setup files runs very fast after it hangs on setup is starting windows....blue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Why would you install "windows 7 and also vista " and then end up trying XP? Do you have an original disk?
完成的
添加一条评论
2个答案
最有帮助的答案
From what it looks like, it seems like it's a bad disc. Try a new XP disc and see of that helps. If you do not have one, you can find clean ISO images online if you know where to look. That said, unless you know where to look the risk of a bad disc is high so you may be better off buying a replacment set of media.
If this does not do it, it's something else. Try running Memtest on the system and see if the memory comes up with anything over a 24-hour window. If nothing does, it's the hard drive or DVD drive, or simply caused by a bad SATA cable.
这个答案有帮助吗?
得分 1
添加一条评论
I have the same problem - I have try with other Windows CD without result.
I have change the BIOS Settings to AHCI, RAID, IDE - without result.
The PC is one Intel 2.4GHz with 2GB Ram and 32GB SSD Sata
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shahzad Rehman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,837
