跳转到主内容
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 个问题 查看全部
No screen after glass replacement
Hi there,
i have no screen after glass replacement the glass i ordered
is full soldered from the supplier on eBay.
when i plug the iPad with iTunes i heard the sound of connection but still no screen on iPad.
I'm not sure that because of the backlight, coz i powered off the ipad before began to fix the cracked screen.
thank you for your help.
Abdel,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
It is either backlight or LCD. You can know for sure if it is backlight by testing across the backlight fuse for continuity. If the multimeter beeps, it is not the fuse. If not, then it is the fuse.
I think there are five or six of us that regularly do ipad mini backlight repair. FYI $50 isn't the best price out there right now for just a straightforward fuse replacement.
这个答案有帮助吗?
得分 1
添加一条评论
Hello Abdellatif, does the iPad have NO picture or when you turn it on is there a very fait picture. If so this would be your backlight. Sometimes shutting off the iPad isn't enough with the mini's and you actually need to disconnect the battery terminal for it to not burn up that backlight. I would try disconnecting the backlight now and see if that fixes the backlight issue however if that doesn't the is a company that does backlight repair for $50. Go to cyberdoc.com to check them out!
Best of luck!
这个答案有帮助吗?
得分 0
3条评论:
Hi DonleySeibel,
I appreciate your fast replay
My Ipad mini have no picture when i turn it on,no picture nothing
but i can hear SIRI said "Siri is not availible connect to internet"
If that caused by this blacklight i will send it to cyberdoc.com.
Than you.
Abdel,
完成的
Hmmm it usually doesn't turn off the picture completely I would check and make sure that your LCD is all the way plugged in and maybe try disconnecting the battery terminal and then reconnecting is. Also are you using an ASD static-free mat? This can cause problems with the mini although not common it can happen!
完成的
Hi,
Do you think it's better to send it to cyberdoc.com ?
By the way i don't use ASD static-free mat.
完成的
添加一条评论
If it is the backlight then yes, unless you are very comfortable with micro soldering.
这个答案有帮助吗?
得分 0
添加一条评论
I second the power cycle. Disconnect the battery or preform a hard reset to see if this remedies the issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Abdellatif 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 257
