跳转到主内容
Released in November 2013, this model of the HP 2000 series is the perfect device for those on a budget, but don't want to sacrifice performance.
34 个问题 查看全部
Why wont my computer turn on?
No matter how long I hold the power button, it will not start up. I have tried pressing the power button several times, my computer is fully charged, and I see no signs of physical damage. What should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 12
评论:
My hard drive connector cable broke and I got a replacement however now my computer won't turn on. This only occurs when I attached the hard drive to this cable. If anyone knows how to fix this please let me know. Thanks
完成的
My. Hp2000 didn't statup
完成的
添加一条评论
5个回答
最有帮助的答案
There are many reasons your computer may not be turning on. One possible solution is that your device may have a bad battery. A quick way to test this is to remove the battery and plug in your device's AC adaptor. If your computer turns on, your battery is most likely the root of the problem and will have to be replaced. If this does not solve the issue, there may be an underlying hardware problem that needs to be addressed. Visit HP's Support Page for more details.
这个答案有帮助吗?
得分 1
添加一条评论
Remove the hard disk connector from the board and try starting it. If it start, that means you have a hardware problem. contact me for the repair.
这个答案有帮助吗?
得分 0
添加一条评论
Firstly, check the AC charger if it has the right current, if it is OK then remove the battery and plug in the charger if it does not then open the computer and read the power line with you digital meter as to whether is running through the motherboard
这个答案有帮助吗?
得分 0
添加一条评论
I removed and replaced the little internal battery next to the hdd, started with a thermal error message. Clearly due to a hardware fault.
这个答案有帮助吗?
得分 0
添加一条评论
I have honestly had this problem as well as a 14 yr old teen trying to get it to boot up as stated in the more professional comments take out your battery and if you plug in your charger and it boots up still with a black screen it’s a corrupted or bad battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dominic Riccoboni 将永远感激不已
浏览统计数据:
过去的24小时: 3
过去的7天: 10
过去的30天: 38
总计 7,483
