跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
My vibrator and proximity sensor is not working
Hey
My friend gift me one iphone with broken display and proximity sensor, so i bought one from ebay and i assembled it, but the sensor is still not working.
Also i recently noticed my vibrator was not working and so i removed another from dad's iphone and used it but still nothing
im from italian, sorry for my english :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Cut two hole out of the electrical tape and place over the sensors
这个答案有帮助吗?
得分 1
5条评论:
but it is weird because if i tap it with finger light should not pass
完成的
Look I'm giving you advise that is tryed and tested and works if you choose not to take that advise no problem
完成的
If you have changed the vibrate motor and it's still not working you need to change the volume , mute and headphone jack flex that's were the vibrate motor gets it's power from.. As for the proximity not working it's possible that to much light is getting in and causing the sensor not to work .. I simply use the electrical tape trick to fix this
完成的
what is that electrical tape trick ?
完成的
im not saying it is wrong :) i just want to be sure it is not anything else before disassembly the iphone again
完成的
添加一条评论
If the proximity sensor still isn't working, you may need to replace the power button and sensor.
While you've got it open you may want to replace the vibrator with a brand new one. iFixit has them for only $9.95
iPhone 4 Vibrator图片
指南
iPhone 4 Vibrator Replacement
难度:
中等
20 - 40 minutes
iPhone 4 Power & Sensor Cable图片
指南
iPhone 4 Power & Sensor Cable Replacement
难度:
困难
1 - 2 hours
这个答案有帮助吗?
得分 0
1条评论:
i already tryed one working vibrator but still not working
so about power sensor i need change cable? hm it looking hard this part
thank you for the rapid ansewer :)
完成的
添加一条评论
添加你的答案
Nikkolo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 197
