跳转到主内容
修复你的物品
维修的权力
商店
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
116 个问题 查看全部
Why does the drive stop responding when connected to the USB sometimes
Sometimes the drive is not recognized after it is plugged in. Even though you can feel the disk rotating, the light does not glow nor is the drive recognized by your computer. This behaviour erratic.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Once this has happened it can cause master directory damagethat will increase problems until the drive is hosed. Use Disk Utility->repair disk for directory damage, back up your data. N.
完成的
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
3个回答
已选择的解决方案
I would suspect that the drive is not receiving enough power at times. Does this always happen at the same USB connection? If so does moving it to another USB port allow it to work properly? Of course if the drive is powered by external means I would worry the drive may be failing. Ralph
这个答案有帮助吗?
得分 2
评论:
Once this has happened you can have Master Directory damage that will cause continued problems. Use Disk Utility to repair directory damage. N.
完成的
+ agreed, different ports offer different power levels
完成的
添加一条评论
You may check your Energy setting for 'Put Drives to Sleep' and ensure that is off.
Update
You could have a bed drive (even if new). Look, if a company makes a million of something there is a good chance that at least one of them is bad. I have a FireWire drive that is externally powered and sometimes it just stops. I think it is the drive itself.
这个答案有帮助吗?
得分 1
添加一条评论
The energy setting just made the difference for me. I was using this as a bootable volume for a new snow leopard computer, and the default settings for both battery and power adapter were turning off the drive whenever I tried to use it to boot. Helpful tip. Thanks.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rakeshv79 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,276
