跳转到主内容
The Asus Transformer Pad TF300T is an Android tablet computer released in April 2012. The Asus Transformer design includes an optional docking keyboard that “transforms” the tablet into more of a laptop computer.
35 个问题 查看全部
I can't charge my tablet
Hi there,
I can't charge my tablet and I think it's something to do with the actual tablet, not the charger. I have tried a different charger and still nothing.
The only way I saw my tablet was charging when I have connected it to my laptop with USB, but it was really really slow and I have to just leave it. If I will be using the tablet while charging with a laptop the battery % goes down. Also, it is not showing me that Android "storm" icon when it's charging it.
Not sure what to do with that. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
最有帮助的答案
Kos , "while charging with a laptop" is what will not work for you. The original charger has 15v 1.2A (18Watts). For normal charging, a charger would have to have an output at least 12v and 1.5A (18Watts). Your laptops USB port, or any other computer USB port will only provide 500mA (0.5A). Double check the "tried a different charger" values. Use a new cable as well. Since it is charging, however slow, on your laptop, I'd say your issues are most likely not with your tablet. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
I have had this exact same problem, and it means that the wall plug part of the charger is not working properly. That needs to be replaced. The cable is not the problem.
这个答案有帮助吗?
得分 0
1条评论:
I had asimilar problem and it turned out to be the charging cable.
完成的
添加一条评论
I have not tried changing from my laptop because of the power level issues discribed above although the plug pack of the charger still gives the output that the information on it's outside specifies according to my multimeter
I just want to prevent me getting another broken laptop after connecting the TF300 to it
Could charging through the USB-1 port be a long shot option? Like some phones are charged through a USB-3 port?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kos 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 6,031
