跳转到主内容
Repair guides for cell phones manufactured by Panasonic.
14 个问题 查看全部
Panasonic KX-TG5110 Cordless Phone will not stay charged?
Charge new battery but will not stay charged for more than an hour is that the norm. when they stayed charged the whole day phones are three years old
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Bob, the Panasonic does suffer from poor battery performance. It is a common complaint. You said staying charged for an hour, if that means that you can use it for an hour, that is actually pretty good. Anyhow, I would replace the battery one more time to make sure that the first battery pack was not of low quality. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
Where do you buy the batteries if phone is 6 years old?
完成的
rayford13 what model is your phone and where are you located?
完成的
添加一条评论
最有帮助的答案
It could be a bad port that appears to be charging but does not. I have also seen devices with signal problems do this. It struggles to find the tower constantly so the battery runs down quickly.
这个答案有帮助吗?
得分 1
1条评论:
jamee, this is a 5.8GHz cordless phone. They are usually not plagued by searching for towers etc.
完成的
添加一条评论
添加你的答案
Bob 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 3,081
