跳转到主内容
Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
199 个问题 查看全部
Why does my PS2 show a 'Brwser/System Configuration' screen on some ga
My Playststion 2 opens to a screen that says 'Browser/ system configuration' screen on some of my games. It will not load game when this screen pops up. It also says to use a Playstation or Playstation format game. What does this mean??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 15
11条评论
When i play any game nd when the game is start so my screen pop up and in the bottom it shows black screen nd the game is pop up i play on half tv nd the half tv is black plz tell me any solution
完成的
It's because your disk tray is too high up put pressure onto the top of the tray with the disk in and lid closed and it will load up. If it stops when you remove pressure keep something heavy on it
完成的
@Baconchops09 thank you!!!!! I have thrown away 4 ps2s and was getting ready to toss this one! Ur 'trick?' Worked! Thank u!!!!!!!!!!
完成的
So i turn on my ps2 and when i get to the home screen all i mean ALL the words are pink, blue or gray . Also when i get into the game the words are so out place that you can't even read it. Someone please help me.
完成的
So i turn on my ps2 and when i get to the home screen all i mean ALL the words are pink, blue or gray . Also when i get into the game the words are so out place that you can't even read it. Someone please help me. by max
this is maybe a BIOS corruption and it means that your device is pretty f..ked up
完成的
显示更多的6条评论
添加一条评论
2个答案
已选择的解决方案
Are you trying to play copied games ?
if not - it's possible that the laser has problems to read the games.
most people are saying thet the laser is defective and needs to be replaced.
but i had a few ps2's with laser problems and all of them were only dirty - the dust is "burnt" on the laser. i've cleaned them with a slightly wet microfibre cloth and that was it - the are all running without any problem
这个答案有帮助吗?
得分 10
8条评论:
Then it shows READING DISC, DISC CANNOT BE READ
完成的
I'll retry doing that.. But isn't a microfiber cloth gonna get all of its fiber sticker to it like dust as well? Thanks
完成的
PD के game nahe dekha ta hai serf browser or confregration dekhata hai please help
完成的
I used to play a 4 disk game on my ps2 with no problem and had saved 6 files on my memory card. I lost the game and bought a new set of it, but it won't let me save or load. The message says memory card not inserted. I tried it with my tekken 5 game and it works just fine. What do I do?
完成的
Please it is a new one a man in my area told me that my pile needs configuration please is that true
完成的
显示更多的3条评论
添加一条评论
Try to buy a new MEMORY CARD. Some ps2's are starting the console from memory cards. Your system configuration in memory card might be corrupted or deleted.
这个答案有帮助吗?
得分 6
4条评论:
pls I use to play my ps2 with memory card and I travel and come back I try to play my ps2 again but is not reading my memory card it only shows me browser/configuration settings pls someone should help me pls
完成的
Put in a memory card and everything worked perfectly.
完成的
My PS2 shows only browser/system configuration what can I do
完成的
I unscrewed the casing and wow the amount of dust it had gathered just by being in a carrier bag tucked away, I only use when I work away & not used since last November. Would be easier to get a Henry vacuum up against the fan at the back and let the vacuum do it's magic. PlayStation works fine now.
完成的
添加一条评论
添加你的答案
wade webb 将永远感激不已
浏览统计数据:
过去 24 小时: 45
过去 7 天: 224
过去 30 天: 1,052
总计 171,778
