跳转到主内容
The Nokia Lumia 800 is a Windows Phone smartphone with a 3.7" display and 8-megapixel camera. It is also known as the Nokia Sea Ray. Released in November 2011.
I am unable to charge the phone
The connecting pin inside the phone charging port is broken so I am unable to connect the charging cable to the phone to charge it. Can this be repaired?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
John flint, seems to be somewhat common. The charging port is soldered onto the logic board. Here is a good video on how to disassemble your phone. Then you will have to desolder the port from the logic board. Not an easy task since it has small contacts. You'll need some good skills and good equipment. the port is available at places like this. If you have never soldered on a logic board or if you do not have the tools, I would just have somebody do it for you. Not a complicated repair for somebody with experience. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
I think its best that you ask someone. One guy lost his phone trying to unsolder
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
John flint 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 2,327
