跳转到主内容
修复你的物品
维修的权力
商店
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1972 个问题 查看全部
Can I upgrade the speaker in my iPhone?
I would love to get higher quality sound from my iPhone 3GS. Is there a way to do this without having to use a separate set of speakers?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
3个回答
已选择的解决方案
Yes, it can be done. It would take quite a load of work to first find the correct speakers with similar dimensions and then dismantle the iphone and replace it and making sure that it works! You're better off just using external speakers or a dock! The quality difference would be too small to actually bother.
这个答案有帮助吗?
得分 7
添加一条评论
It'd be very difficult to replace the speaker assembly in an iPhone, but that's not to say it can't be done if the right replacement parts were available: the latter is a question for the awesome iFixit team =).
这个答案有帮助吗?
得分 6
添加一条评论
The internal speaker is based on a plastic chamber located at the back of it improving the sound quality. If you change only the speaker,without any change of the chamber, the result may be no mentional.Redesigning the chamber is out of a common customer's ability and will, as well as the result doesn't worth the effort.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Mitra Cline 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 30,193
