跳转到主内容
The Samsung Chromebook XE303C12-A01US laptop features an 11.6" screen and a 16 GB SSD hard drive. This small notebook computer allows for easy access to the Internet and can run various web apps.
34 个问题 查看全部
Can I create & restore an 'image' from/to the hard drive
hi, i have been thinking of creating a total hard disk image of this cromebook. windows and mac.
then, i would want to 'restore' the image of the windows to this chrome book, and see whether can it run windows.
also, i would like to restore mac hdd image to this chromebook and see whether can it run iOS
can i do that?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
HI, technically, this Chromebook COULD run windows, but Samsung has tweaked the bios so that you can't install anything else. However, the specifications are right. Here is what you would need to do:
1. Hack your BIOS settings. This is incredibly difficult to do. You have to open your Chromebook, meaning you have to remove the 12 screws in the bottom and wrap some electrical tape around the BIOS to stop the protection activity, thus allowing you to hack into your BIOS settings. After you have done that, you can remove boot loader settings. To do this, hit F4 and change the sequence.
2. Flash new BIOS. This also needs to be done carefully to avoid damaging the Chromebook.
3. After hacking the BIOS settings and flashing new BIOS settings, you can install Windows 8. You will need to have the Windows 8 Operating System stored on a flash drive. You would not be able to use an external CD-Rom drive since Chromebooks do not come equipped with a CD drive. After this, all you need to do is follow the installation instructions.
As you can see, it would be difficult, and would require you to open up the device. However, if you're up to it, then feel free to go ahead!
You could always do this . It's a lot easier, and safer for the system. Plus, depending on the type of cpu your system has, it might not even be able to run windows at all (not to discourage you)!
这个答案有帮助吗?
得分 1
评论:
This information is mostly inaccurate. The only version of Windows 8 that it could run is RT which is designed for ARM based processors. Also the XE303C12 uses Uboot, not BIOS. ARM processors cannot run x86 or x64 compiled programs so NONE of your regular Windows or even Linux programs will run. You could run them in emulation but it is inefficient. Check out ArchWiki and wikipedia for more information.
完成的
添加一条评论
添加你的答案
Adrik Kuzmin 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 480
